Power dissapation?
Discussion in 'The Projects Forum' started by Porkchop, Feb 5, 2007.
  1. Porkchop
    Feb 5, 2007
    17
    Hi guys nice forum :)
    Little question.
    I have a regulator and a bridge rectifier mounted on the same heatink.
    I have calculated the power dissipated in the regulator and from this i have found the minimum heat sink C/W which is fine.
    How do i calculate the rec power though ?
    There is 25V sec from the transformer going in. And with a max draw of 7A
    Also when i know the power dissipation of the rec how do i account for this in my heat sink thermal resistance calculation. Do i just add the to powers of the reg and rec together
    Making Q the total sum?
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    Hard to follow what you're saying with the abbreviations. Can you add the part numbers and a a pointer to the datasheets?
  3. kubeek
    Sep 20, 2005
    4,689
    806
    power dissipation = voltage drop x current
    in case of bridge rectifier it is 2*0.6V x 7A = 8.4W
    You just add this number to the heat the regulator makes and recount the heatsink.
  4. Porkchop
    Feb 5, 2007
    17
    Sorry. When i say Rec i mean rectifier
    When i said Sec i meant the secondary winding of the step down transformer supplying the low voltage AC to the rectifier.
    I just want to know how to work out the power dissipated in the rectifier first Please.
  5. Porkchop
    Feb 5, 2007
    17
    Smashing thank you. I did get that result but i assumed it to be far to low tbh :rolleyes:
    Going off this it looks like i might be better having it on a seportat heat sink, i think i might actually be heating it up lol
    Thanks guys!
