Power delay circuit
Discussion in 'The Projects Forum' started by Marcc1981, Oct 7, 2008.
  1. Marcc1981
    Oct 7, 2008
    Hi everyone I have been looking about on the net to try and find this and stumbled across this forum.
    Ill give you a little bit of backgroud first of all.
    I have had a project on the go for some time building an arcade cabinet and basically I need a delay on a timer that can be adjusted likend into my TV power on.
    I have everything in the cabinet being powered on by one button I just need the TV to come on 1 min after everything else.
    Why I hear you ask?
    Well the bios on PC systems outputs at 31khz and on a normal TV this is not good, I have a tool that makes windows run in 15khz so it appears on the TV fine, but the bios cannot be changed and I dont want to damage the TV.
    If anyone could help here it would be greatly appreciated as the cabinet is going to be a sealed unit and I will have no access to the on/off button of the TV.
    Thanks alot
  2. iONic
    Nov 16, 2007
    1,422
    68
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    A time-delay relay would work for this.
