Power Cord retainer insert tips needed
Discussion in 'General Electronics Chat' started by Gdrumm, Jul 28, 2014.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    I'm rewiring a vacuum cleaner today, and I'm having difficulty getting the little thru hole cor retainer thru the hole.
    I squeezed it, with the cord inside, in my vice, and that looked like it was going to work, but then it didn't.
    I don't have a good grip with my right hand so I've tried surgical clamps. and tiny needle nose pilers. I even applied a little grease. no good.
    I looked on Ebay for a tool, and on Youtube as well, but I'm not sure what such a tool would be called.
    This isn't the first time I've struggled with these little wrap arounds, so if there is a tool, I would buy it.
    If theres a trick, I will ty it.
    As always, thanks for your help.
    Gary
  2. JohnInTX
    Jun 26, 2012
    2,392
    1,051
    They are Heyco strain relief bushings (they have a gazillion of them) and use special pliers to compress them and shove them through the hole.
    I paid about $50 for mine and use them a lot. EDIT: That was awhile ago. Looks like the R100A is about $113.
    Here's more info.
    Have fun.
  3. paulktreg
    Jun 2, 2008
    621
    124
    I've always found the serrated pipe holder part of an ordinary pair of pliers does the job.
    #12 likes this.
  4. Gdrumm
    Aug 29, 2008
    684
    36
    Thanks for the link.
    A bit pricey, but it may be the way to go.
    Gary
  5. Gdrumm
    Aug 29, 2008
    684
    36
    The one I have is relatively small, too small for pliers.
    I will try my needle nose vice grips.
  6. Gdrumm
    Aug 29, 2008
    684
    36
    Okay,
    Here is what worked.
    One larger surgical clamp East - West, on the larger outside shoulder.
    One smaller surgical clamp, Norh - South, near the base, where it enters the thru hole in the vacuum cleaner. It finally started into the thur hole, then I tapped on the back end of it, and it popped right in.
    Thanks for your input.
    If I have to do this more frequently, I'm going to have to spring for a kit.
  7. MrChips
    Oct 2, 2009
    12,623
    3,451
    Have you tried a pair of vice grips? That usually works for me.
  8. shortbus
    Sep 30, 2009
    4,086
    1,665
    The key to those wire grip/strain reliefs is proper sizing. They are made with different internal diameters(ID) to fit the wire. The grip ID allows the wire insulation to be compressed and then expand after insertion in the hole of the appliance. An improper ID will either not allow the compression or will be too loose when inserted.
  9. KMoffett
    Dec 19, 2007
    2,584
    234
    I've used modified ViseGrips to reinstall Hayco "strain reliefs". Oxymoron...because the strain relief is the point where the cord jacket takes the most strain, and usually cracks. :( I've picked up cheap, small, ViseGrip knock-offs and ground a curved channel in the end of both jaws. This helps keep the jaws centered on both parts of the strain relief, and gives you a lot of force.
    I never use those feed throughs on anything new. :)
    Ken
  10. mcgyvr
    Oct 15, 2009
    4,784
    973
    The tool is called "callused Chinese fingers" :D
