power consumption
Discussion in 'General Electronics Chat' started by vustudent, Nov 7, 2009.
  1. vustudent
    Thread Starter Active Member
    Mar 11, 2009
    38
    Does a plugged in, but powered off computer consumes energy?
  2. ELECTRONERD
    May 26, 2009
    1,146
    16
    Yes it does. One of the computers I have will have this LED inside it glow even though the computer is powered off.
    It's almost like a wall-wart or adapter; it's plugged in but there is still power dissipation across the transformer, rectification diodes, and filteration caps. But the power consumption isn't very much, it will significantly increase when a load is applied.
    Austin
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    Yes. You also have a clock and some RAM to keep going. It draws a little bit when it's off.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    A portion of the power supply (a "pilot" 5v supply for ATX form factor) is always running, even when it's turned off.
