Power Calculation
Discussion in 'General Electronics Chat' started by keyboardcowboy, Jul 30, 2014.
  1. keyboardcowboy
    Dec 31, 2012
    25
    The label on an air conditioner reads the following
    Voltage: 220v
    Current Rating: 9.8 Amps
    If i am to calculate the power consumption, will i just multiply the current and the voltage?. The thing that i do not understand is since this is AC wouldn't i consider the power factor in the power calculation, but then again another thing is if the power factor would have mattered wouldn't the manufacturer have mentioned the PF on the label :confused::confused:
  2. mitko89
    Member
    Sep 20, 2012
    123
    19
    Ask yourself the questions: 9.8 Amps what - P-P, RMS? Does your air conditioner have a huge internal capacitance and inductance so the power factor is an issue? Do you think if it had such a issue the manufacturer wouldn't bother to correct the pf?
    keyboardcowboy likes this.
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    it dosnt have to have huge inductors or capacitors to affect power factor, a loaded or unloaded induction motor will change power factor.
    current and voltage on labels is usually rms, not peak to peak. simple multiplication of volts and amps will give you watts but then you have to understand thats running power, not startng power.
  4. mitko89
    Member
    Sep 20, 2012
    123
    19
    My questions were to guide him what exactly he can do with his input data and to make a simple assumption.
  5. crutschow
    Mar 14, 2008
    13,529
    3,393
    Multiplying the volts and amps will give the VA not watts since, as you noted, the PF needs to be known to get watts. The PF is normally not a big concern for small home appliances so is not given. The amps are given for sizing of the circuit and fuses/breakers. Typically a fully loaded AC induction motor has a PF of .85-.9 so the actual power consumption would be 10%-15% less than the VA.
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    since power consumption is measured in va, not watts, and pf is not given, simple multiplication is enough.
  7. crutschow
    Mar 14, 2008
    13,529
    3,393
    The power meter on your house measures watts, not VA. It ignores the reactive part of the current.
  8. kubeek
    Sep 20, 2005
    4,691
    806
    The 9.8A will most likely be maximum current consumption so that you can properly size your breakers and wiring. It will vary depending how many fans and motors are running at a time.
  9. NorthGuy
    Jun 28, 2014
    611
    121
    You cannot calculate power consumption from the label with any reasonable precision. It has bad power factor (it's a motor). It cycles. It might be variable speed. The label is not very accurate.
    The best way is to buy a Kill-A-Watt meter and measure directly.
