1. aka-rato
    May 11, 2012
    58
    HELLO
    I want to make a power bus for my circuit, i just dont know if its possible because i have two different voltages the other one is 220v and the other one is 24v and i want to make only one bus for all the voltages. im using multism.
    thank u
  2. MrChips
    Oct 2, 2009
    12,646
    3,458
    What is a power bus? Is it this?
  3. ErnieM
    Apr 24, 2011
    7,442
    1,628
    If you have two voltages you need two power buses, one for each voltage.
  4. aka-rato
    May 11, 2012
    58
    I mean CAN BUS, and a "CAN BUS is a serial bus protocol to connect individual systems and sensors as an alternative to conventional multi-wire looms."
    So in this case this BUS will only accomodate power/voltage wires, instead of having so many voltage wires running to different plugs to draw power, I can have 1 bus going to the main supply and supplying all the power wires with power. I hope this is understandable
  5. aka-rato
    May 11, 2012
    58
    Okay thanx
