Power and Voltage Help (I blanked)!
Discussion in 'General Science' started by NinaFarac, Jan 1, 2016.
  1. NinaFarac
    Jan 1, 2016
    Hey everyone, I'm having a 'blanking' moment:
    Today, my teacher gave us an example of an electrical source that had enough power to power a LED light, but not enough voltage. We then had to offer a suggestion to change the circuit in order to make enough voltage.
    Can someone please explain how you can have enough power, but not enough voltage? I don't see how this fits in the general power-voltage relationship.
    Thank you in advance!
  2. djsfantasi
    Apr 11, 2010
    2,905
    879
    Power is what? In other words, power is the relationship between what two values!
    The answer is P=VxI. If the voltage is too low, and the current available is higher than necessary - you have sufficient power but not enough voltage.
    Take a typical but mythical LED circuit for illustration. The LED specs say it has a forward voltage of 2V and typical current of 15ma. It's power requirement would be 0.03W
    Now consider a power supply of 1V and 30ma. Power is also 0.03W. But there is insufficient voltage to illuminate the LED; it requires 2V.
    NinaFarac likes this.
  3. NinaFarac
    Jan 1, 2016
    Thank you for your reply djsfantasi! I was able to work it out after I posted the thread :p
