Power and Current Requirement Calculation of MOSFET
Discussion in 'The Projects Forum' started by mishra87, Aug 25, 2016.
  1. mishra87
    Jan 17, 2016
    203
    I have to switch through mosfet with 5V@80mA with Rdson = .4ohm.
    Now
    1. Power dissipation
    2. Current Consumption
    3. Input Power
    4. Output Power
    5. Efficiency
    Thanks..!!!
  2. wayneh
    Sep 9, 2010
    12,382
    3,241
    Ummm... Have you tried to make any of these calculations yourself? Why do you care what the values are if you don't know what the words mean?
    1. P = I^2 • R all inputs given
    2. Given as 80mA
    3. P = V•A all inputs given
    4. Eqn. (3) minus Egn. (1)
    5. Eqn. (4) / Eqn. (3) x 100%
    mishra87 likes this.
  3. mishra87
    Jan 17, 2016
    203
    I know the meaning of terminoligy still I had doubt- thats why I asked
    1- I agree
    2- 80mA is load current so u can say current consumption. If one need to deliever load current 80mA at 5V ..so is that same with input current...!!!
    Current consumption means what is the input current Mosfet will draw.
    3. Now input power
    4. Out power.
    Please interrupt if I am wrong...!!!!
  4. wayneh
    Sep 9, 2010
    12,382
    3,241
    Does charge accumulate within the MOSFET? No. So that means current in equals current out.
    The slight exception to this is the gate of the MOSFET, which has a small capacitance. So a tiny charge actually is required to enter the MOSFET to turn it on, and this charge must be drawn off to turn the MOSFET back off. This becomes relevant at high (>50kHz?) frequency, as this charge/discharge current adds up in proportion to frequency.
    This has nothing to do with the load current, which is typically much larger.
  5. mishra87
    Jan 17, 2016
    203
    Thank you so much...!!!
