I would like to control 2 motors, one is 6V and 740mA and another one is 5V 200mA. But my I/O board (digital to analog) can only gives up to 10V and 5mA and the motor manufacturers do not provide any motor drivers. How can I drive this motors using through this I/O (digital to analog) board? Do I need a power amplifier? Can you recommend a specific power amplifier or any other alternatives? Soon I will also need to control the motors using PID and other control algorithms.
I've tried to construct the power amplifier as in the Fig. 2 in the attachment: Vin is a 12V voltage supply and RL is a 1k ohm resistor, but it does not work. Instead of amplifying the power, the voltage and current across RL is almost zero. But the voltage across the capacitor is high? Or does it only work or AC?
What should I do? Please help me. Thanks
