So you're not driving a 'standard' 50Ω load. Are you driving some sort of inductive loop? Perhaps you could elaborate your requirements a little more.the output power should be 1 watt and this amplifier i have use for medical application. the input current is 100 mA and i want out current of around 1.15 A. which configuration is the best C , D or E.
There is a minor problem. 1 Watt of output power at 1.15 A will mean a very low output voltage of perhaps 0.87 Volts (RMS?). Designing things like power amplifiers at such low voltages is well tricky to say the least. You will have trouble biasing your output stage. Gain of 10 is not unreasonable. It might make more sense if you designed for say 15 Watts of output power. Then you would have 13 V @ 1.15 ASo you're not driving a 'standard' 50Ω load. Are you driving some sort of inductive loop? Perhaps you could elaborate your requirements a little more.
While an inductive loop arrangement isn't likely to radiate much in terms of far field, I think a 15 W level would not be permissible for the ISM band - which I believe includes 13.56MHz.There is a minor problem. 1 Watt of output power at 1.15 A will mean a very low output voltage of perhaps 0.87 Volts (RMS?). Designing things like power amplifiers at such low voltages is well tricky to say the least. You will have trouble biasing your output stage. Gain of 10 is not unreasonable. It might make more sense if you designed for say 15 Watts of output power. Then you would have 13 V @ 1.15 A
.Class E has disadvantage about in terms peak voltages.. it goes 3.5 VDD compared class C which goes upto 2 vdd
by Jake Hertz
by Duane Benson
by Aaron Carman
by Aaron Carman
