Power adapter voltage?
frank55
Joined Dec 6, 2013
313
Hi guys; can you tell me what is the correct load Voltage on a Power Adapter,
for example i have here a 3v DC 200 mA power adapter when i test it on my Fluke it reads about 7v,without load, is this too much ?
i rarely find a Power adapter that reeds the exact voltage that is in the adapter specs always have 2 to 3 volts or more ,what is too much voltage?.Thanks
#12
Joined Nov 30, 2010
18,224
Depends on the load. Will the load break when it gets too much voltage?
If you have a switch between the power supply and an appropriate load, the voltage will drop into range instantly when you flip the switch on.
Demanding a power supply act correctly with no load?
Only if you have something better than the cheapest you can buy.
MaxHeadRoom
Joined Jul 18, 2013
28,702
If this is the older Wall-Wart etc type supply these typically were linear supplies and relied on the rated load to bring the voltage down to the stated V.
Recent ones for some time now are practically all SMPS and should measure the label voltage.
Max.
frank55
Joined Dec 6, 2013
313
Thanks; i found this very small adapter out in the street on top of a garbage can, this could be a phone charger or something else i don't know,
it's a Class 2 power supply input 120VAC 60hz 7w output 3vdc 250ma
mcgyvr
Joined Oct 15, 2009
5,394
Unregulated vs regulated power supplies..
Most new ones are regulated (aka they will output their marked voltage regardless of load)
Most older ones and still some today are unregulated.. (aka they will output their marked voltage only when loaded properly)
If its a 3V and you measure 7V without a load its unregulated (or your meter is broken :) )
MikeML
5,444
Most of the ones that utilize a real transformer are unregulated, some are AC out, some have just one diode (half-wave), some have just a bridge rectifier, some have the rectifier(s) and an electrolytic filter capacitor, which is usually relatively small, so when load, there is a lot of ripple...
#12
Joined Nov 30, 2010
18,224
I remember, I have an old charger rated for 3 volts. It went with some computer speakers that also ran on a pair of C batteries. Presto, a reason for that charger to live. :p
