Potting Compound
Discussion in 'General Electronics Chat' started by tresguey, Mar 7, 2014.
  1. tresguey
    Apr 22, 2013
    55
    My company is having me look for a similar potting compound to what we use so I figured this would be the perfect place to ask. We use Stycast 2651-40FR currently. This compound is a bit pricy so we are looking for something similar. Any help would be great.
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    I usually use a resin based such as body filler, not sure it meets the cost and standards you need?
    Max.
  3. tresguey
    Apr 22, 2013
    55
    I have used polyester resin from US Composites for a lot of my projects. The price is right for just over $100 for 5 gallons. But our EE says no way.
  4. #12
    Nov 30, 2010
    16,704
    7,354
    Then ask him which types would work.
    A single, "not that one" means almost nothing. You can't, in a practical way, go shopping and comparing every type in the world and then ask for what he wants.
  5. tresguey
    Apr 22, 2013
    55
    Our EE has a few screws loose. I have tried to ask he just said it must be fire resistant and capable of handling 250°F
    #12 likes this.
  6. mcgyvr
    Oct 15, 2009
    4,791
    976
  7. strantor
    Oct 3, 2010
    4,302
    1,989
    I've used the black potting from MG^^. It was pretty badass. Not advertised to be good for 250F but their "High temp epoxy" is advertised for 392F. I wouldn't hesitate to try it. I
  8. #12
    Nov 30, 2010
    16,704
    7,354
    Right. Styrene is flammable in nearly every form. At least you have more information now. And, most EE's have a few screws loose. That's why we gather in nerd zones like this website. :D
  9. GopherT
    Nov 23, 2012
    6,320
    4,044
    What physical / electrical / chemical properties do you need?
    What properties of Stycast 2651-40FR can you live without?
    If none, there are generally no cheap alternatives while still achieving specified flame retardancy and dielectric strength. You can use BONDO or anything else that hardens but one batch may have different dielectric properties than another since it is an off-label application and not specified.
  10. #12
    Nov 30, 2010
    16,704
    7,354
    Bondo is a form of styrene. Has anybody found out if it burns?
    I have only applied Bondo, never found out if it burns.
    I'll ask my nephew. He plays with body work more than I do.
  11. GopherT
    Nov 23, 2012
    6,320
    4,044
    I was trying to be sarcastic about trying any random paste (including the aforementioned bondo) that is not tested and specified for an application - potting. The Henkel (formerly Loctite) product he is using is expensive for a reason, it is the product development and ongoing quality testing of the manufacturers incoming raw materials and finished product.
    Note: BONDO is a polyester resin (like most Fiberglas resins). It is blended with fillers like mica, milled glass and has adhesion promotion additives to improve adhesion to steel. This is not intended as a potting compound. The adhesion promotors will likely allow conduction at higher temps and voltages - enough to allow heating of the bondo. Then again, it depends what you are looking for...
    #12 likes this.
  12. kubeek
    Sep 20, 2005
    4,689
    806
    So things like the compound being noncorrosive and nonconductive don't matter?
    GopherT likes this.
