Potentiometric Volt measurement
Discussion in 'General Electronics Chat' started by tommyboytml, Mar 6, 2013.
  1. tommyboytml
    Mar 6, 2013
    Why do the headphones stay silent when the voltage through the circuit matches the drop over the resistor being measured? I assume that they stay silent when you go over the drop also?
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    What circuit?
    Ken
  3. tommyboytml
    Mar 6, 2013
    Any circuit using test leads.
    I understand we can use the headphones as a null detector but why do they go silent? Is it because the voltage goes to zero when the voltage matches that of the component being tested? And do they stay silent if we use more volts than the amount dropped at the resistor being tested?
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    Doesn't make sense. Can you post an example?
    Ken
  5. MrChips
    Oct 2, 2009
    12,636
    3,455
    Some kind of AC Wheatstone bridge measurement system?
    Something like this?
  6. kubeek
    Sep 20, 2005
    4,689
    806
    I bet MrChips is on the right track, but seriously, do you think that a multimeter (which definitely has test leads) does have some headphone connector or something? People here are usually very skilled at guessing what a person is actually talking about, but you should not count on it.
