potentiometers
Discussion in 'General Electronics Chat' started by jhsmith87, Oct 5, 2012.
  1. jhsmith87
    Oct 4, 2012
    i am looking to get a 1k ohm resistor, although my local store only the lowest one is a 5k ohm. and this is going on a circuit that is running on 12v 3a dc power supply. it will be going through a coil first so that may reduce some power, but after the coil i need the potentiometer even if i get the 5k ohm one that they have the specs on it say wattage ratting .5w tolerance 20%.
    so wouldnt that fry the potentiometer? or is the coil that is wound 500 or more times of 26g wire be enough resistance to keep it from frying?
  2. Kermit2
    Feb 5, 2010
    3,847
    963
    12/1k = .0012 amps
    12 x .0012 = .0144 watts
    Seems you would be ok, UNLESS you try to reduce the resistance of the pot down below 100 ohms. At that point you would be in the 'let the smoke out' zone.
    Amps = volts div. by resistance.
    Watts = volts times amps
    I leave it to you to figure out how low you can take the resistance before things start to glow red and smoke. :)
    A schematic of HOW you plan on connecting power and ground and how you plan to wire in the pot. would be extremely helpful to those who would help you.
    (using the pot to control the base of a power transistor connected in shunt mode would be more reasonable - depending again on how you plan to interconnect things.)
  3. ScottWang
    Aug 23, 2012
    4,925
    777
    If your VR 5K only used 2 pins, then you can do like this:
    1K + 250Ω = 1.25K
    1.25K parallel VR5K : 1 .25K // 5K = 1K.
    So you got one VR5K.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    You slipped a decimal point. 12V/1k=12mA.
    Power=V^2/R=12*12/1k=144mW.
  5. Kermit2
    Feb 5, 2010
    3,847
    963
    Thank you Ron.
    Looks like my math is rustier than I thought.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    I can relate.:D
