potentiometer wiper wiring??
Discussion in 'Electronics Resources' started by simontheng, May 24, 2011.
  1. simontheng
    May 12, 2011
    HI guys, just want to check is there any potentiometer which has the the wiper pin at its last pin.
    i have just screwed my pcb, i had put the wiper pin in pin 3 which is wrong!!! so is there any potentiometer that it's pin is swap?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I've never seen a 3/8ths or 9 mm pot that does not have the wiper as the center pin.
    You now have an opportunity to discover the great utility of an Xacto knife in cutting foil traces so you can use 30 ga wire to rework the circuit.
  3. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Me neither. In fact I can't remember any pot that did not have the wiper in the center.
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    10-turn cylindrical wire wound pots. CW-front, CCW-middle, Wiper-rear. ;)
    Ken
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Don't know that I have ever seen a Beckman Helipot on a PCB though.
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    Bourns 3082 series has the wiper at the screw end.
