Potentiometer sensitivity
Discussion in 'General Electronics Chat' started by RyanBRZ, Oct 30, 2014.
  1. RyanBRZ
    Oct 22, 2014
    12
    I recently replaced a potentiometer on an amplifier, using the same level resistance as the original (20k linear). I noticed that once I get to about 30% (turned clockwise) I see no difference up to the 100% position. Can I put in a higher impedance pot to get more accuracy so I'll see a level of difference at each position? The original pot that came with the amplifier works the same way.
    Thanks!
  2. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Can you post a link to the schematic of your amp?
  3. djsfantasi
    Apr 11, 2010
    2,911
    881
    Are you sure it was a linear pot?
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    volume controll pots are not usually linear, they use log taper pots to mimic the response of the human ear. that keeps the volume changes from crowding up at the bottom of rotation.
  5. RyanBRZ
    Oct 22, 2014
    12
    The pot that came with the amp is stamped B203; I used a DMM, set it to 20k and it reads 19.5 at full resistance and the taper is definitely linear. This is for gain control on the amp, I'm not sure if that's considered the same as volume but I suppose it's the same right?
    I'm better off with log taper?
  6. crutschow
    Mar 14, 2008
    13,505
    3,383
    Yes, a log taper should give you a more linear pot movement relative to the perceived sound level.
    You can mimic the response of a log pot reasonably closely by putting a 2k to 3k ohm resistor from the wiper to ground. You might try that to see how it works. The only problem would be if the source can't linearly drive the lower resistance that this configuration provides. If so, you would need to use a 200k ohm pot and a 20k to 30k ohm resistor.
  7. RyanBRZ
    Oct 22, 2014
    12
    Is a log pot preferable over the alternative? I just ordered the 20k log pot.
  8. MrChips
    Oct 2, 2009
    12,642
    3,457
    What is the resistance when the knob is turned halfway?
  9. RyanBRZ
    Oct 22, 2014
    12
    ~10
  10. MrChips
    Oct 2, 2009
    12,642
    3,457
    If it is 10kΩ at midpoint then it is linear.
    A 20kΩ log pot should be better.
  11. RyanBRZ
    Oct 22, 2014
    12
    Switched to log pot and it works perfect. Thanks for the help!
