Potentiometer Question
Discussion in 'Homework Help' started by nfd802, Apr 22, 2010.
  1. nfd802
    Apr 24, 2009
    I am coaching 4th and 5th graders in an Elementary School Science Olympiad event about circuits. I am not an electrical engineer or hobbiest, but volunteered that I could probably handle this event if no one else stepped up to coach (I am a materials engineer).The kids are being tested on DC circuits - lamps, resistors, LEDs, diodes, capacitors, etc.
    One of the other elements is a potentiometer. We have covered what it does, how it can be used as a variable resistor as well. One of the kids asked what the 4th terminal was for (I had wondered, too). I had actually opened one up to show the kids how it worked. We could see, and verified with our multimeter that it didn't seem to be connected to the resistor. I told the kids I would try to find out its function.
    So - my question is: Why is this mysterious 4th terminal there?
    Thanks in advance,
    Nancy
  2. retched
    Dec 5, 2009
    5,201
    313
    If it is an audio POT, it can be a separate tap. Used for stereo volume control.
    Do you have a picture or a brand name and model number?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Might that terminal have been a locating lug to go in a hole to orient the pot when mounting in a panel? A photo would be interesting.
  4. retched
    Dec 5, 2009
    5,201
    313
    True, it may be for stability when soldered to a pcb. That way it wont wiggle when its turned. Some power jacks use an additional pin for mounting rather than power.
  5. nfd802
    Apr 24, 2009
    Wow - such quick responses.
    I have uploaded a couple of pictures - poor quality, sorry (only have my cell phone camera right now). My guess was that the 4th terminal had to do with mounting.
    Thanks again.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Still a mystery. That lug is a solder terminal, not a locating pin. When you rotate the shaft all the way CCW, is there a click?
    Can you get a name and part number off the case? All I can see is that it's an inexpensive carbon pot with a strange lug.
  7. someonesdad
    Jul 7, 2009
    1,585
    141
    It's not a typical pot -- they have 3 terminals or 5 if it includes a switch. My guess is it was an OEM part for some assembly and the user wanted the extra solder terminal to help in the wiring of the assembly.
  8. nfd802
    Apr 24, 2009
    No clicking. When assembled nothing seems to touch the lug.
    Definitely an inexpensive part - we get kits with a fair number of different components for $10.
    Numbers on the case
    100L-13-1204-00
    R1379511 The last "1" is a different size
    No name. It is a 100 Ohm pot.
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Nothing to work with. It seems to be a cheapo 100 ohm pot with an unusual extra lug. As to the purpose, giving a couple of adults a small unsolved mystery seems to be about it.
  10. KL7AJ
    Nov 4, 2008
    2,047
    294
    Measure the resistance from the orphan terminal to each of the other three terninals. See if it's directly connected to any of them.
    Eric
  11. nfd802
    Apr 24, 2009
    Thanks everyone who replied.
    I don't feel quite so stupid now. I will show the kids that it is not electrically connected to the other terminals and tell them it is not typical for a pot to have this extra terminal.
  12. loosewire
    Apr 25, 2008
    1,584
    435
    Since the kits are $10.00 maybe surplus parts are from anything.
    Someone had good Idea how use surplus to make a buck.
  13. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That is probably the best explanation. The pot got made to perform some function, but that terminal did not get connected. Instead of a trash heap, it got put in a parts grab bag.
  14. Engr
    Member
    Mar 17, 2010
    114
    5
    I think it is another terminal where you can tap....That's what I think
  15. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That may have been the intent, but it does not seem to have worked.
  16. hgmjr
    Jan 28, 2005
    9,030
    214
    If the extra terminal happens to be connect electrically to the outer case of the potentiometer's metal housing, it could serve a couple of purposes. One would be a convenient solder point to the chassis (assuming that the chassis is metallic). Another purpose would be to provide a connection point to the case to allow shielding the pot against EMI susceptibility or emission. The latter purpose would be particularly useful if the pot is mounted in a plastic (non-conductive) chassis.
    hgmjr
  17. n1ist
    Mar 8, 2009
    171
    16
    Perhaps they use the same PCB for both tapped audio pots (in which case it would connect to a tap on the resistive element) and for untapped pots (like you have). That way, the manufacturer only has to stock one type of PCB.
    /mike
