Potentiometer Question
Discussion in 'Homework Help' started by PetrusB, Feb 22, 2010.
  1. PetrusB
    Feb 14, 2010
    5
    "In the following circuit, RL is a potentiometer which varies from 0 to 30 Ohms. Plot (1) The voltage of R2 and (2) the power dissipated by R2."
    I understand the overall concept of a potentiometer, and I've read several web sites on them, but I'm still not 100% sure how to use standard nodal or mesh analysis to solve a circuit with a potentiometer and our textbook doesn't address the subject.
    Here is what I did. Can someone please tell me if this is correct or not?
    I replaced the potentiometer circuit with this second circuit, where the potentiometer is replaced with two separate resistors which resistance values that must sum to 30 Ohms (if one is 5 Ohm the other must be 25 Ohm). This diagram shows 15/15, but it could be two values that sum to 30.
    From there, for a given RL setting, I can solve for the current, voltage, and power across R2.
    Is this valid? Is there a better way?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Hint: replace the potentiometer with two resistances. One is the variable Rx and the other is the value of the potentiometer minus Rx.
    hgmjr
  3. PetrusB
    Feb 14, 2010
    5
    Thanks. That's what I did in the op, but I wanted to be sure. Appreciate the confirmation.
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    I might add that in the TRUE application of a potentiometer, R2 would either not exist or be of infinite value. As soon as you start drawing current through R2, you no longer have a true potentiometer, but instead, a rheostat.
    Just a fine point...but it does simplify things immensely. :)
    eric
