potentiometer question for a project, please help
Discussion in 'The Projects Forum' started by vasdef1, Apr 15, 2009.
  1. vasdef1
    Apr 15, 2009
    Hello, I've built a few simple amps and have used the recommended value pots for them.
    But say I had one that required a 1K pot, and I used a 5k or a 1 meg. What are the differences? Thanks.
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    The difference will depend on how the pot is used. If you can supply a specific schematic, we can discuss the effect of replacing a specific pot.
  3. vasdef1
    Apr 15, 2009
    ok, here's the schematic. What I'm asking is, do I have to use the 1k dual gang pot in place if c3 and c4, or what are the consequences of using a 5k, etc..
    Also, it did not list the value of the volume pot. Any insight would be greatly appreciated. Thanks
      File size:
      22.5 KB
      21
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    When you change the potentiometer from 1K to 5 K the gainschange will be on a smaaler part of the potentiometerrange and the rest will hardly give any change.
    The change will be heard if the value gets below 1K.
    Greetings,
    Bertus
