Potentiometer Problem
Discussion in 'Homework Help' started by yan500, Jul 12, 2011.
  1. yan500
    Jul 12, 2011
    48
    Hello All,
    I'm just dabbling in electronics for fun as a summer project but I really need some help on a problem. The problem is question 16 http://www.allaboutcircuits.com/worksheets/e_divide.html
    I just can't figure out how to account for the 1k resistor. I've tried adding the two resistors together to figure out the voltage reading but that doesn't even make sense because the more resistance you have, the more voltage you will have.
    I don't really know how to account for that resistor. Any help is much appreciated.
  2. blah2222
    May 3, 2010
    565
    33
    I messed that up sorry, look below haha...
    yan500 likes this.
  3. yan500
    Jul 12, 2011
    48
    Hmm...I'm getting 1.67V using your method but that is not the right answer. Or maybe I am doing something wrong.
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    With the pot set at 25% then the value from wiper to ground is 1.25kΩ. The value from wiper to +10V is 3.75kΩ.
    The 1.25kΩ (wiper to ground) is in parallel with 1kΩ. So from wiper to ground the effective resistance is 0.556kΩ.
    The divider output is then Vout=10*(0.556/(3.75+0.556))=1.29V
    yan500 likes this.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    So
    V_{out}=10X[\frac{%5k||1k}{(5k-%5k)+(%5k||1k)}]
  6. yan500
    Jul 12, 2011
    48
    Got it! I was visualizing it the wrong way, thanks a bunch!
