Potentiometer In Parallel
Discussion in 'The Projects Forum' started by ilnar, Jun 18, 2012.
  1. ilnar
    May 8, 2012
    16
    here is my potentiometer and it's wiper is connected in parallel with 12k resistor.
    my wiper also serves as an output . so... how do i order this circuit to output 2.1 volts?
  2. wayneh
    Sep 9, 2010
    12,405
    3,256
    You need to separate the wiper from ground, and extract whatever voltage you want from the wiper.
  3. DickCappels
    Aug 21, 2008
    2,785
    676
    Get the right value for the pot and you will have 2.1 volts when at 80%. The rest is left as an exercise.
  4. wayneh
    Sep 9, 2010
    12,405
    3,256
    shortbus likes this.
  5. cork_ie
    Member
    Oct 8, 2011
    348
    58
    R= total pot resistance and assuming it is a linear potentiometer
    2.1 Volt is dropped across 20% of your pot,
    2.9 Volt across 12K & 80% of your pot in parallel.
    [0.2R= 2.1/I ] & [ 1/ (1/.8R + 1/12000)] = 2.9/I =>
    10.5/R = I = [2.9 x (1/.8R +1/12000)] = [2.9/.8R + 2.9/1200]
    = 3.625/R + 2.9/12000 =>
    6.875/R = 2.9/12000 =>
    R= (12000x 6.875)/2.9 = 28.448K
    Theoretical Pot size to get 2.1V at the wiper as in your drawing is 28.448K
    In practice you are unlikely to get one outside a standard value
    ilnar likes this.
  6. ilnar
    May 8, 2012
    16
    you are the GOD of Pots :))) thank you very much.
