Potential Voltage
Discussion in 'Homework Help' started by mellowmon, Jan 29, 2009.
  1. mellowmon
    Jan 24, 2009
    17
    They say that the amplifier in sound reinforcement technology acts for the most part as a constant voltage source.
    If the amplifier rated of 100 watt at 4 ohm and have a peak supply voltage of +/- 28 volts.
    what is the formula on how to determine or calculate the voltage of potential from the amplifier?:rolleyes:
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you expand on your question? This is hard to understand -
  3. mellowmon
    Jan 24, 2009
    17
    inorder to calculate the rigt speaker for 100 watt amplifier we must find out first the voltage of potential coming out from the amplifier
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Haven't you already stated it as being +/- 28 VDC?
    Besides, ones looks at the box and selects the speaker that has the desired impedance and is rated at the desired power handling. If the speaker is 4 ohms and rated for 100 watts, the voltage is not significant.
    For 100 watts and 4 ohms, Power = I squared * R . 100/4 = 25, so the current will be 5 amps. E = IR, or 5 * 4 = 20 volts. That's a bit rough-and-ready, but the voltage just isn't an issue.
    My big amp runs +/- 75 volt rails, and I haven't lost a speaker yet - and that's not because I don't turn it up. About 330 watts per side.
  5. mellowmon
    Jan 24, 2009
    17
    so, what is the basis in getting the voltage of potential? is it in Vrms or Vpeak?
    for 100 watt amp. the peak supply voltage is +/-28.28 volts and a 20 volts Vrms.
  6. mellowmon
    Jan 24, 2009
    17
    One more thing,
    They say that when it comes to electrical measurements, it is much easier to measure the voltage potential across a resistive load than it is to measure current flow through the circuit itself.
    then, if we are going to measure the voltage potential from the current flow through the circuit itself. what will be the correct calculation for it? is it in Vrms or in Vpeak?
    cheers..:rolleyes:
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Vrms is correct.
