Potential equalization
Discussion in 'General Electronics Chat' started by copucopu, Aug 18, 2014.
  1. copucopu
    May 26, 2014
    21
    Does anyone know where can I get a part like on the picture?
    I think it is a potential equalization... How is it technically named?
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Could be four Zener diodes wired in parallel?
  3. wayneh
    Sep 9, 2010
    12,374
    3,226
    Are those diodes on a heat sink? Can you show us the other side of that thing?
  4. ErnieM
    Apr 24, 2011
    7,435
    1,625
    This is not an individual part, it is an assembly.
    Green and Yellow wires ID these as the protective earth ground. Short lengths of wire have lugs press fit in place and are bolted onto whatever those four terminals are. There is also a wire with lug on a screw right to the housing itself.
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    What does the back side of the gray plate look like?
  6. copucopu
    May 26, 2014
    21
    I am sorry I dont have it physically in my hands. But I have these two pictures. One is from the side and one is when the part is mounted in the wall.
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    Equipotential earth bonding sockets for a medical environment?
  8. Kermit2
    Feb 5, 2010
    3,845
    963
    Agreed. Earthing distribution tie point. Notice that all the area is made of plastics. Such wiring is needed due to the extensive use of non conducting housing to provide safety grounding for outlets and other equipments.
  9. copucopu
    May 26, 2014
    21
    Yes it is in a hospital.
    Does anyone know where I can get something similar?
  10. ericgibbs
    Jan 29, 2010
    2,582
    389
  11. MrChips
    Oct 2, 2009
    12,624
    3,451
