Pot Orientation Question
Discussion in 'The Projects Forum' started by tracecom, Sep 15, 2012.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,879
    1,396
    In the following schematic, with the pot fully clockwise, there is minimum resistance between pins 2 and 3, and maximum resistance between pins 1 and 2. In that condition will there be minimum or maximum drive to pin 9 of the audio amp? (I think I have the pot backwards.)
    Thanks.
  2. #12
    Nov 30, 2010
    16,704
    7,352
    Minimum...
  3. tracecom
    Apr 16, 2010
    3,879
    1,396
    I was afraid of that, but better to find out now than after I have PCB's made. :rolleyes:
    Thanks.
  4. #12
    Nov 30, 2010
    16,704
    7,352
    If you're going to make circuit boards before you build and test this circuit, you should also know that your volume controls are installed completely wrong.
    Pin 3 goes to the input jack, pin 2 goes to the amplifier chip, and pin 1 goes to ground.
  5. tracecom
    Apr 16, 2010
    3,879
    1,396
    Yeah, that concern was what prompted my original question; I thought I had it wrong. Here is the corrected schematic. If you see anything else, please point it out.
    Thanks again.
  6. #12
    Nov 30, 2010
    16,704
    7,352
    Looks good from here.
    tracecom likes this.
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    Is the pot linear taper, or audio taper? If linear, then it is ok to swap ends...
  8. tracecom
    Apr 16, 2010
    3,879
    1,396
    It is audio taper and is connected as shown in post 5. I have now breadboarded the circuit and the volume goes up as I turn the pot clockwise, which is what I want. So, apparently, everything is ok.
