Since I don't have an svg file at hand to try it, it is very likely that .svg extension isn't allowed by the site.
Try either: Manually changing the extension, ie changing the filename to myfile.svg.txt. Keep in mind that the intended recepients will have to change the extension back to change the file.
Or: Put it in a .zip file and upload it. Some members are suspicious of .zip files, so clarify exactly what is in the file.
