Post numbering failing
Discussion in 'Feedback and Suggestions' started by atferrari, Mar 29, 2016.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,669
    784
    In this ongoing thread, the fuse resistor seems to be still a mystery. Also those two posts with the same number.
  2. jrap
    Administrator
    Jun 25, 2006
    966
    202
    That's a new one. I wonder if it's a caching issue or something else - I'll look into it. Thanks!
  3. WBahn
    Mar 31, 2012
    18,088
    4,917
    @atferrari Could you provide a link to the thread in question?
  4. atferrari
    Jan 6, 2004
    2,669
    784
    Hola William,
    This takes me in surprise; I was sure I had inserted the link in the OP, inside "this". Now is not there. Here it goes again.
    BTW, now the thread shows up somehow shortened (maybe split by a mod?). Those posts are not visible (in my PC at least). Not akin to forensic investigations myself today....:)
  5. WBahn
    Mar 31, 2012
    18,088
    4,917
    Yeah, it appears that the thread has been edited (probably split), so it's impossible to see if the problem you spotted still exists.
    I've seen post numbering issues before that resulted from actions that had occurred since the page was last refreshed. If you make a post to a thread that you've previously posted to, you will notice that your prior posts on that page do not show your new message count. So it appears that the browser is merely adding new information to the page display instead of reloading the entire page -- which certain conserves bandwidth. But if someone else deleted a post since you last got a complete refresh, you will have a mix of new and old information. This should resolve itself if you manually refresh the page (unless strange caching effects are at play).
  6. atferrari
    Jan 6, 2004
    2,669
    784
    I had not contributed to that thread and it was my first time visiting it.
  7. WBahn
    Mar 31, 2012
    18,088
    4,917
    My best guess is that you accessed it in the middle of edits that were in progress.
