Hi, I am just starting learning about radio and there something I don't quite understand when it comes to data/bandwidth limits.
Lets say I transmit a signal at exactly 1000000hz (1Mhz) and encode 1 and 0 as full power or half power (amplitude modulation) for each herz to get 1 million bits/sec (1Mbit) and then do the same at a frequency of 1000002hz and again at 1000004hz etc. all the way up to 2000000hz so I have half a million separate signals (with 1hz spacing) at between 1Mbit & 2Mbit data-rate per signal. my total data rate would be something like 500000K Mbit or (500Gbit). Clearly in the real world this is not possible and I would like to know why. Is it because I would need half a million transmitters and receivers or is it possible to listen to or transmit all frequencies at once with a single antenna using oversampling with software defined radio. I get the feeling i'm missing something here so If somebody could fill me in it would be most welcome.
