I have a question with regards to measuring continuity using a DMM ohms setting on a non powered circuit board. I read the following here:
"Avoid: Any other kind of continuity tester for PCB work. Never use the Ohms, Diode or Beeper function on your DMM to measure continuity on a circuit board!" http://pdp-8.org/tools.html
The above site recommends to use a zero beeper such as this one:
http://www.jensentools.com/stanley-supply-services-zero-current-audible-continuity-tester/g/1214
The above linked tool indicates there is zero current through semiconductors and it is "CMOS SAFEST".
I also read here that "It is possible to damage semiconductors when using an ohmmeter to test them."
Am I correct to understand that if I use my DMM ohms setting to measure continuity on a circuit board (such as to check if a trace is broken), there is a possibility that components such as semiconductors (e.g. CMOS ICs) could get damaged? Would you consider it worth it to buy the above tool for measuring continuity on circuit boards (esp. those of 70s/80s vintage) instead of using a DMM?
Thank you
Thank you
