Hey guys!! I have a sonic cleaner. it takes 3 c batteries and has two holding tank cups about 2 inch diameter. I need to clean a small gokart carburetor and I've tried everything.
I'm wondering if there might be a way to up the voltage and make a bigger holding tank for it. The carb is about 6 inches long and 1.5 inch wide.
Or maybe it has enough volts as is, and I can use a plastic tupperware to make the holding tank bigger?
Edit: mybad its 3 AA
