Possible New Solution to Turbulence.
Discussion in 'General Science' started by BR-549, Feb 27, 2015.
  1. BR-549
    Sep 22, 2013
    2,184
    421
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    the talk about the magnetic field reducing viscosity sounds like the ads for magnets to put on your gas line in your car.
  3. Kermit2
    Feb 5, 2010
    3,854
    968
    i thought those magnets went on water pipes to "soften" the water. get rid of those expensive and messy salt units that claim to soften hard water. just throw them out. Our scientifically proven magnet system will replace it easily and quickly without all the mess!
  4. BR-549
    Sep 22, 2013
    2,184
    421
    I remember those.....and those venturi plates that you bolted underneath the carburetor. Some in the air cleaner.
    And of course the water atomizer.
    Those are quite some pump savings.....but it didn’t show the field setup or the cost.
    And I hadn't heard of the effect on blood.
    But if it really reduces the turbulence that much....the oil companies will be using it.
    I thought it was curious that you don't have to have a continuous field on.
  5. wayneh
    Sep 9, 2010
    12,405
    3,256
    Interesting solution. And yeah, the blood flow thing is interesting. Could bleeding be mitigated (or made worse) by exposure to the appropriate field?
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Somehow magnetic fields was substituted for electric fields. Their is a huge difference between them.
    GopherT likes this.
  7. GopherT
    Nov 23, 2012
    6,339
    4,084
    Definitely says, electric field. Also, electric field can easily align molecules (remove random orientation) and decrease viscosity in the direction of the field (while, like the article says increase viscosity normal to the field.
    Also, an 11 hour effect is not unreasonable as it takes a long time to re-randomize high molecular weight molecules - especially when they are in a alignment in a flow direction that promotes that alignment.
    This will definitely work - a school like Temple knows the damage that falsified data has done at other schools. I am sure it is not a scam.
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
    Not quibbling about the article. Apparently, Professor Tao is the real deal too.
    However, 11 hours (approximately 40X10^12 nanoseconds) for the randomization of macromolecules seems more than a few orders of magnitude too long for liquids, based on my experience with fluorescence polarization. Here is a chart modeling the effects of molecular weight on loss of fluorescence polarization.
    Source: http://www.lifetechnologies.com/us/...-highlights/fluorescence-polarization-fp.html
    With a fluorescence half life of 20 nS, there is a great deal of randomiztion for molecules with molecular weights up to 100,000. On what sort of molecules and matrices was your comment based?
    John
    cmartinez likes this.
  9. nsaspook
    Aug 27, 2009
    3,020
    2,386
    I think it's more of a system effect. The polarization forms a system that seeks to minimize local energy like the alignment of small iron dipole particles into lines of iron filings from the magnetic field (field lines don't actually exist) of a magnet or electric field lines in a fluid. Each set of macromolecules is locked into it's minimized energy state alignment by others that are in turn interlocked. When away from the field the created system still exists as a static system that requires energy (or the major loss of energy as a system) to disrupt it from the charged minimized energy state.
    https://www.flickr.com/photos/physicsdemos/3174122601/in/photostream/
    jpanhalt likes this.
  10. GopherT
    Nov 23, 2012
    6,339
    4,084
    Polarizing with the electric field from polarized light vs. An electric field from high voltage charge will give you very different results.
    I worked with A two phase system that tended to form 'emulsions'. Pressure and flow were necessary to prevent reforming the micelles and high viscosity structures. It was almost 20 years ago. I showed this article to a former coworker who was full time on the project for several years. He didn't know if he should laugh or cry.
    Oil-sands are ugly mixtures with lots of heteroatom compounds that will form 3-d supramolecular H-bonded structures that build viscosity much higher than molecular weight alone would indicate. They may not be 2-phase emulsions but still likely supramolecular 3-D structures. The polarization eliminates the structure to a great degree and increases laminar orientation with flow direction which is maintained by pressure and flow.
  11. jpanhalt
    Jan 18, 2008
    5,699
    909
    If it is like an ordered emulsion, I can believe it. I have had emulsions last for years until I got tired of looking at them and threw them out. If they are that ordered, have they been subjected to X-ray diffraction analysis? I suspect there are experiments to support the theory that weren't mentioned in the news release. My reference point was, of course, ordinary solutions in water, not liquid crystals and emulsions.
    Thanks for the further explanations.
    John
  12. alfacliff
    Dec 13, 2013
    2,449
    428
    any moving electric field creates a magnetic field. just as any changing magnetic field creates an electric field.
  13. wayneh
    Sep 9, 2010
    12,405
    3,256
    There's no such thing as an object that is not moving. Everything in the known universe is moving.
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    Relativity rules.
  15. WBahn
    Mar 31, 2012
    18,093
    4,920
  16. BR-549
    Sep 22, 2013
    2,184
    421
    I think we will see more of this in the future.
    And I think we'll come to find that the "field" effect is always composed of two equal orthogonal components...the electric and magnetic.
    That is a huge change in viscosity at ambient temps.
    This is a huge savings in energy.
    Perhaps in the future, this might be applied to ships and planes.
    Maybe Scotty's field coils are in our future after all.
