Possible Correction In Volume IV
Discussion in 'Feedback and Suggestions' started by Professor Thom, Nov 4, 2010.
  1. Professor Thom
    Jun 6, 2008
    7
    Hi guys, haven't been on here in a while. Here is the link to the page I'm referring to.
    http://www.allaboutcircuits.com/vol_4/chpt_3/1.html
    In the paragraph below the first Figure, 2nd line. "Because its saturated, the transistor drops very little voltage between collector and emitter, resulting in an output voltage of (practically) 0 volts."
    Should it be 5 Volts if there is almost no voltage drop?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    This is correct.
    This is correct.
    The power supply stays 5V. I don't see the problem.
  3. Professor Thom
    Jun 6, 2008
    7
    Ugh, sorry... was having a blonde moment. I forgot that the transistor acts as an open if there's no voltage to the base. I think I just got confused.
