Positive to negative voltage regulator
Discussion in 'General Electronics Chat' started by gusmas, Oct 24, 2009.
  1. gusmas
    Thread Starter Active Member
    Sep 27, 2008
    239
    Hi guys, i need a regulator that converts a positive input voltage to a negative voltage, any ideas?
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    How much current do you need?
    If it is low current, you could take a look at the ICL7660.
    See datasheet.
    Greetings,
    Bertus
  3. gusmas
    Sep 27, 2008
    239
    Under 1amp
  4. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    1 Amp will the 7660 not manage.
    Then you will have to look for an real switching converter.
    Perhaps you can find someting in the powersupply cookbook:
    http://www.maxim-ic.com/cookbook/powersupply/
    Greetings,
    Bertus
  5. AdrianN
    Apr 27, 2009
    97
    the kid likes this.
