positive / negative power supply from two separate units?
Discussion in 'General Electronics Chat' started by unprovoked, Apr 2, 2009.
  1. unprovoked
    Apr 2, 2009
    I would like to power a circuit with an op-amp (acting as voltage to current converter) and two transistors (acting as current amplifier) with +12V and -12V. The output current can be as high as 3A. So, I need a dual power supply +12/3A and -12/3A.
    Can I use two table-top power supplies (Jameco #220442; regulated switching), and reverse the leads on one of them? A previous post stated something relevant, but I don't completely understand:
    "This does not apply to non-isolated DC power supplies where one terminal is hardwired to a power common, (or neutral) connection and you are not free to swap polarities simply reversing connections to your application."
    How do I know if the table-top supply I'm interested in has a "terminal hardwired to power common"? It's datasheet says:
    2.5. 2-wire input AC line (Line Neutral)
    3.11. The DC ground will be isolated from the AC neutral and AC line
    I am not an engineer, so please try to explain in the simplest terms possible.
    Thank you!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The statement -
    - tells you that the output is not hardwired to the AC wiring. You can stack the supplies to get your +/- 12 VDC.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. KL7AJ
    Nov 4, 2008
    2,047
    294
    I can't speak specifically to your supply, but most lab quality supplies have floating outputs, where you can tie either end to ground...or another supply. I imagine yours would work fine.
    eric
  5. KL7AJ
    Nov 4, 2008
    2,047
    294
    By the way, if you want a really cool project to work on, you can build a tracking regulator...it's a bipolar supply that always keeps the ground at precisely the midpoint. Great way to learn about op amps~
    Eric
  6. KL7AJ
    Nov 4, 2008
    2,047
    294
    http://www.datasheetcatalog.org/datasheets/400/501050_DS.pdf
    You could clone this thing using garden variety op-amps for the feedback.
    eric
  7. unprovoked
    Apr 2, 2009
    Thanks for the incredibly fast responses and also for the link to mpja.com (which is so much cheaper).
    For other similar supplies, if I can't find a spec sheet, how can I tell if DC ground is isolated or not? For example, how do you know if http://www.mpja.com/prodinfo.asp?number=17261+PS or http://www.mpja.com/prodinfo.asp?number=16918+PS is isolated and thus the leads reversible?
    Out of curiousity, what would happen if the DC ground was not isolated and someone tried to reverse the leads?
