In the book I'm reading the author states that there is an equal amount of positive charge in the ground that matches the negative charge in the clouds above. That the positive charges are drawn to the clouds and that they will rise above the power lines.
::"image removed due to hosts image bandwidth constraints"
What are positive charges? I thought it was the electrons from negatively charged particles that were going to do the moving. What is happening with positive charge movement? I understood it as electrons are what moves. What is this business about positive charge movement?
THanks in advance.
THanks in advance.
