Positive and negative supply from a single positive input
Discussion in 'The Projects Forum' started by electrophile, Apr 25, 2016.
  1. electrophile
    Aug 30, 2013
    100
    Hi, I'm trying to create a +/- 3.3V supply from two LD33s (or the TLV1117-33). Would the attached schematic work?
  2. ScottWang
    Aug 23, 2012
    4,934
    777
    Does the +3.3V and -3.3V has any common ground?
    In another words are +3.3V and -3.3V connecting to the same Load?
  3. ericgibbs
    Jan 29, 2010
    2,604
    396
    hi e,
    As drawn the circuit will not work.
    Recheck the 0V [ gnd] connections.
    You could use a OPA to give a virtual ground if powered from say 9v.
    E
  4. Bernard
    Aug 7, 2008
    4,244
    423
    No, if using common ground.
    How much current is needed on neg. supply ? For a few mA might use a 555 oscillator circuit to produce a neg. V, but + 5V
    might be too low to give high enough neg. V to regulate. Use another 555 as V doubler or buy a boost-buck module with Neg. output?
  5. electrophile
    Aug 30, 2013
    100
    Yes they will be used to power a LMV324M opamp.
  6. crutschow
    Mar 14, 2008
    13,516
    3,386
    You circuit has both inputs grounded.
    Here's a way to do what you want with the outputs having a common ground point.
    It uses a special voltage regulator that can both sink and source current to allow a split voltage without adding a separate virtual ground circuit.
  7. electrophile
    Aug 30, 2013
    100
    Thanks. Are C3 and C4 decoupling caps? Would something like this work? (attached)
  8. crutschow
    Mar 14, 2008
    13,516
    3,386
    Only if you can guarantee that the positive current will never be more than the negative current, since that excess current has to flow into the output of the bottom regulator.
    That's why I used a regulator that can both sink and source current.
    Yes, C3 and C4 are decoupling caps.
  9. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,708
    1,301
    Not as drawn. Each regulator has a 3.3 V output, so the input must be at least 6.6 V. But wait - each regulator has some headroom requirement, a minimum voltage drop from its input to output. If that is 0.5 V per regulator for example, then the minimum circuit input now is 7.6 V.
    ak
  10. electrophile
    Aug 30, 2013
    100
    I see. The 3.3V will also be used to power the MCU and other peripherals. The negative rail is only for the opamp. So yes the need to sink the excess current is evident. The original schematic had a dual secondary windings flyback transformer which was used to generate the negative rail. That transformer however is not available now. The LT1118 is fairly expensive in my part of the world. Any other replacements that are fairly inexpensive and easily available?
    Thanks AK. I realized that the input would have to be higher than 6V after I posted the schematic :)
  11. crutschow
    Mar 14, 2008
    13,516
    3,386
    Since you only need a small amount of current for the op amp negative voltage, you might consider using a switched-cap converter to generate the negative voltage from the positive voltage.
    Linear Technology and others, sell such devices.
  12. electrophile
    Aug 30, 2013
    100
    I was just about to post on that. I found this chip which is fairly low cost and easily available - Microchip's TC7660S. I could use the +3.3V from the TLV1117-33 to generate a -3.3V just for the opamp here. That would work right?
  13. crutschow
    Mar 14, 2008
    13,516
    3,386
    That should work as long as the negative current is no more than a few mA [see Figure 2-7 in the data sheet which shows output voltage versus load (for various values of input voltage at the zero current point)].
  14. electrophile
    Aug 30, 2013
    100
    Got it. This would power a LMV324M low power version of the 324. That datasheet lists the supply current as 410 uA. Thanks again for all your suggestions :)
  15. crutschow
    Mar 14, 2008
    13,516
    3,386
    Sounds good.
    But note that the negative current would include any negative output current the op amp would have to deliver to its load.
    electrophile likes this.
  16. electrophile
    Aug 30, 2013
    100
    Got it. The output will eventually feed into an MCU. Considering that the TC7660S can drive upto 20mA of negative load current and the opamps are consuming uA's of current, there is plenty of leeway. I'll do some testing though.
