Hello Guys.
I am thinking of building my first project and i need directions where to start.
The project am thinking of is a sensor system that gives change in position as numeric value to a computer. (or the numbers can be evaluated on a computer based on initial position sensed) The detector is tracking points. And these points can also be loaded with radio signal emitters and any thing that helps get accurate position where they are. The detector and points to be tracked are within 40cm X 40cm X 40 cm of 3d area. The important thing is the live numeric data and the points can not be loaded with to much electronics. Power to the points and the sensor can be separate.
if you can direct me with a microprocessor and sensor types that are good for this project i would appreciate it. thanks
