Portable Water Purifier UV Light
Discussion in 'The Projects Forum' started by John Gagnon, Feb 1, 2016.
  1. John Gagnon
    Feb 1, 2016
    I have a 5.5w UV lamp and need to hook it up to a 14.8v battery. What do I need?
  2. cmartinez
    Jan 17, 2007
    3,698
    2,788
    Do you have a spec sheet for said lamp? Or a link to where you bought it at, at least?
  3. Dodgydave
    Jun 22, 2012
    5,154
    772
    Is it a fluorescent tube with two pins on each end, if so you will need a cfl inverter board, like the ones for caravans.
  4. Kermit2
    Feb 5, 2010
    3,851
    966
    Water purification with UV is energy intensive and requires a multi minute exposure time. A few seconds under UV will NOT sterilize drinking water.
    cmartinez likes this.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    Also be sure whatever vessel the water is in is transparent to UV wavelengths that are germicidal. That is usually considered to be UV-C at 254 nm. Unless, of course, you are irradiating through an open top. There are a lot of factors that can interfere, such as dissolved iron salts and so forth. It is risky business on a camping trip. I would not rely on its efficiency.
    John
  6. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Unless the purifier is solely for a small-scale laboratory experiment I suspect you'll need a LOT more than 5.5W do have any useful effect.
  7. Kermit2
    Feb 5, 2010
    3,851
    966
    Two or three drops of regular old clorox bleach is more than sufficient to kill all living microbes in one gallon of water. It tastes like a swimming pool, but will not hurt you if consumed. It is easy to carry and a very small amount can sterilize many gallons of drinking water.
  8. alfacliff
    Dec 13, 2013
    2,449
    428
    my hot tub uses an ozonator, it pulls air through a box with a uv light which ionises the air, which is bubbled through the water in the tub. this works instead of using chlorine to disinfect the water. short wave uv.
