I'm in the process of building a portable speaker tower. The tower will consist of two 8" sub woofers, two 6.5" sub woofers, and two .5" tweeters. I plan on using a dual din head unit and mounting on the top. I will power the 6.5" subs and the tweeters through the built in amp on the head unit, and get another amplifier for the two 8" subs. All in all its 3' tall, 10" wide, and 8" in depth. I would like to add some sort of adapter to make it power able by a wall outlet. I've heard of converting pc power supplys to do this, is that an option. If not, what else could I do? I was thinking of making it deatchable to make it more portable. Connection wise, I was thinking some sort of exterior plug with a female port on the back of one and a male on the other. Lastly, I want to add LED lighting strips to it for an awesome effect. Opinions or suggestions welcome on anything.
