I'm making a portable Nintendo 64 (hence the title).
My questions:
1. How do I go about finding out which way I have to plug the batteries in?
Electricity flows from positive to negative in a battery... but how am I supposed to know if I hooked a battery up correctly, if I do wire it incorrectly (battery to n64 board) will anything burn out?
2. The little solder point thing on the N64 board has a "C" next to it (for composite video out). Isn't there supposed to be 2 connections when ever you are dealing with this stuff? (one for positive, one for negative).
3. Explain Ground to me (as far as this board having connections/pins for it goes).
4. Same thing as #3, except this is for audio.
The board has the L/R audio out pins, but doesn't it need a + and - wire for each?
My questions:
