Portable HV supply - HV return connection
Discussion in 'The Projects Forum' started by johnsy, Jul 10, 2014.
  1. johnsy
    Jul 3, 2014
    28
  2. Dodgydave
    Jun 22, 2012
    5,154
    772
    Looks like what you have there is a miniature ht generator,the return path for the arc is back to the transformer secondary, which may be isolated if you want.
    johnsy likes this.
  3. johnsy
    Jul 3, 2014
    28
    Hi Dodgydave,
    Thank you for the link!
    I'm gonna try that.
    I found a schematic of a usb plasma globe:
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    actually the return for plasma globes sometimes dosnt exist as a wired connection, the rf generated will be capacitivly coupled through the glass and the body touching the glass acts like a capacitive load. did you ever see a plasma globe you had to hold on to a ground return wire to work? they do work better if you are grounded, but still work ungrounded.
  5. johnsy
    Jul 3, 2014
    28
    You might be right on the portable/usb globes.
    On the globes i've tested there was no hv return on the transformer secondary.
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    kind of like where is the return path for corona?
