I want to make a light 'pen' to create calligraphy using light painting photography.
Examples of light painting:
Example1
Example2
Example of a tool I have made using a Led flashlight but one which does not give me enough light.
I was wondering If I can make a pen tool using 1W-6W led cob powered by AA batteries?
Led Cobs pictured below:
I will give the specifications of one of these cobs, the 1W 60 x 8mm.
If somebody can explain taking just this example, I think I can work out the possibilities with others.
COB1 - 60mm X 8mm
1. Chips: Epistar
2. Meterial: Aluminum-alloy plate + COB LED
3. Power: 1W / 3W
4. Input Voltage: DC 2-2.6(Red) 3V-4V (others),Max current :300mA(1W) / 1000mA(3W)
5. Luminous flux: 100LM/W
6. Light Color: Cold White (6000-6500K) , Warm White (2700K-3200K) ,RED(620-630nm),Blue(450-460nm)
7. Size: 60mm*8mm
8. Lighting area: 50mm*7mm
9. Low attenuation, 1000h attenuation<1%
COB2 - 100mm X 8mm
1. Chips: Epistar
2. Meterial: Aluminum-alloy plate + Silicon Rubber + COB chip
3. Power:5W
4. Input Voltage: DC 12V-14V Max current: 400mA
5. Luminous flux: >100LM/W
6. Light Color: Cold White, Warm White, Nature white
7. Size:100mm*8mm
8. Lighting area: 90mm*8mm
I have very little knowledge of these things and I tried finding as much as I could.
I will try and put forward the little I have understood.
Alkaline AA batteries are rated 1.5 volts, while rechargeable NiMH AA batteries I was planning to use are rated at 1.2 volts
Alkaline AA batteries are rated 2500mah, while NiMH AA batteries are rated at 1900mah.
So to power a 12V light, I will have to put 8 Alkaline AA batteries in series in a holder... and similar calculations for others.
And if a cob is taking up 300mA, then using a 2500mah battery, I can get a 2500/300 = 8 hours.
Are these ideas correct?
When will I have to use a resistor?
What other factors do I have to take into consideration?
Are there any better options to make a similar tool?
Example1
Example2
COB1 - 60mm X 8mm
1. Chips: Epistar
3. Power: 1W / 3W
7. Size: 60mm*8mm
COB2 - 100mm X 8mm
1. Chips: Epistar
3. Power:5W
7. Size:100mm*8mm
