I want to power a small credit card terminal rated at 24 VDC 1.5A. I assume the 1.5A is with the built in thermal printer running and not continuous. I need to run the terminal maybe 4 hours a day and will power it down when not needed and will recharge overnight. I have seen a few charger units for 12V Sealed Lead Acid (about 8 Ahr) which would require running the batteries in series and a NiMH charger that would work with a 20-cell pack (series) rated at 2-3.5 amps. Anyone have a better way to go with this? The cheap way out would the the car 12V charger I already have, a couple of small alarm sized Sealed Lead Acids, a switch, fuse and a box. Got anything more sexy? I would not sneeze at "off the shelf".
