Poorman’s Buck Schematic Doubt.....?
Discussion in 'The Projects Forum' started by corefinder, Oct 25, 2012.
  1. corefinder
    Oct 6, 2011
    55
    I have one doubt in this schematic. It has one diode D1. Why it is there won’t it will get short and all the current will drain through it.I have attached the schematic.
  2. crutschow
    Mar 14, 2008
    13,509
    3,385
    What do you mean "it will get short"? Why would it? It's a flyback diode for the inductor current.
  3. corefinder
    Oct 6, 2011
    55
    Its diode D1 I am talking about. Its D3 diode that will work as flyback diode.
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I have taken the schematic from the PDF, so others can view it directly.
    The D1 diode is for the reference voltage for the current setting.
    Bertus
  5. corefinder
    Oct 6, 2011
    55
    Ok I got it.Thanks Bertus.
  6. DickCappels
    Aug 21, 2008
    2,779
    674
    So the answer to the original post, based on Bertus' reply is "Yes, is has current going to ground; that's the way its supposed to work."
    My question (not intending to hijack) is whether the 2 mv/°C drift is compensated for somewhere.
  7. Mustafatarhan49
    Member
    Aug 16, 2012
    56
    What about D2? Why is this D2 used in reverse polarity ?
  8. t06afre
    May 11, 2009
    5,939
    1,222
  9. t06afre
    May 11, 2009
    5,939
    1,222
    The circuit comes from this site ttp://www.instructables.com/id/Poormans-Buck/
    R1 will limit the current through D1 to a safe value for the diode. Without R1, D1 would have been acted as short. And very quickly gone up in flames
  10. Sensacell
    Jun 19, 2012
    1,184
    277
    D1 is acting as a crude voltage reference ~ 600 mv forward conduction voltage.
  11. Mustafatarhan49
    Member
    Aug 16, 2012
    56
  12. t06afre
    May 11, 2009
    5,939
    1,222
    Because the LM393 has what is named a open collector output http://en.wikipedia.org/wiki/Open_collector
  13. Mustafatarhan49
    Member
    Aug 16, 2012
    56
    Ahan yeah I see that! THanks a lot!
