polygon pours
Discussion in 'Homework Help' started by fran1942, Jul 8, 2011.
  1. fran1942
    Jul 26, 2010
    58
    Hello, I am just starting out with creating PCB's using software.
    I have come across the term 'polygon pour'. Is that just when you cover the whole PCB with copper which has gaps around each component and tracks ?
    If someone could just give me a brief rundown on exactly what 'polygon pours' are and when you would or would not use them, it would be greatly appreciated.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Another nice thing with pours is that they leave you with less copper to etch, speeding up the process.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Along with less copper to etch, one of the big benefits is power and ground planes.
    Straight wires or straight traces of a fixed width have inductance, the smaller/narrower and longer the wire or trace is, the greater the inductance.
    But, an infinite plane has virtually no inductance. A copper pour can act more or less like a partially infinite plane. Of course, it's best if you have complete layers dedicated to power and ground, but that's generally not possible for a hobbyist making boards at home.
