Hi All,
I just wanted to know which would be simpler to implement through hardware (software is not a problem for me)
I will be sending 16 bits from a 16 bit shifter, and it seems like I can just shift them serially into the USB port, and then store the bits on the PC and then do my own software analysis. Is that possible ? I have read some articles that imply USB is not that simple to use...
If not, is it possible to do that with the serial port?
Basically my question is: what is simplest way of transferring 16 bits to a PC at any moment in time ?
Thanks in advance.
Thanks in advance.
