police lights
Discussion in 'The Projects Forum' started by deawag, Sep 7, 2010.
  1. deawag
    Sep 6, 2010
    hi,, im your new member,please can you help me...i need a police light strobe circuit diagram and pcb lay outs i will use a 2x8 red led and 2x8 blue led with a power supply of 12 volts
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Have you done a search yet? I've helped a lot of people with this.
    The search is on top of the screen, I'd use advanced search.
  3. tom66
    May 9, 2009
    2,613
    214
    You want everyone to do your school work for you?
    Help can be offered, but please show what you have already done.
    First considerations would be how to drive the LEDs. You could use resistors, but it would be quite inefficient. Ideally, you would use a constant current power supply or an LED driver.
    Secondly, you have to consider your power supply. You say 12V, but do you plan to run this from a car? The battery voltage is not static. It varies from as low as 11.8V to about 14V, make sure your circuit can handle these voltages. Also, note that it's not necessarily stable; it can vary quite a bit and you can get large spikes of voltage (transients.)
    The oscillator (the part commanding the red and blue LEDs) will be easy. A 555 timer could probably do the job.
    In many places it is illegal to produce a replica police light; make sure you check the law where you live.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Where is "buru un Iligan city". A country might be more appropriate.
    Is this for a RC car or a police vehicle?
  5. KMoffett
    Dec 19, 2007
    2,584
    234
  6. deawag
    Sep 6, 2010
    hello guys could you please help me i need a circuit diagram of police lights and pcb lay outs.tnx...
  7. R!f@@
    Apr 2, 2009
    8,792
    771
    What type of components do you have access to.
    Like discrete part or micro controllers with a programmer.
    Or with logic IC's
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    I asked this on your other thread, but is this for a a car or for RC?
    http://forum.allaboutcircuits.com/showthread.php?t=42642
    BTW, double posting the same thread is strongly discouraged here at AAC.
    I have helped with other threads, you have but to search. I said the same thing on the other thread.
  9. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    As Bill_Marsden already asked you, is it for RC (remote control model) or a real car?
    Bertus
    PS I noticed the threads are merged.
  10. Kermit2
    Feb 5, 2010
    3,852
    968
    Get a regular strobe light/circuit. Xenon flash ect.
    And put red and/or blue cellophane over the lens.
    Viola! Instant red and blue flashing lights.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    As soon as we can establish what it is used for we can start helping.
  12. campeck
    Sep 5, 2009
    194
    Blamo.
  13. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The lights may ONLY be used on a RC / model car.
    The light may NOT be used on a real car.
    Bertus
  14. tom66
    May 9, 2009
    2,613
    214
    Don't worry with those transistors and resistors there's no way that would drive a big LED or an array.
  15. campeck
    Sep 5, 2009
    194
    That schematic must be for slightly higher powered LEDs than the standard 20mA. The reds have over 30mA through them. When I built this I just used the source current of the 4017 itself to drive the LEDs.
  16. Wendy
    Mar 24, 2008
    20,772
    2,540
    It is very similar to the one I showed in LEDs, 555s, Flashers, and Light Chasers. I suspect the OP has made it obvious this is for the real deal though. We need it confirmed.
    The OP has made 5 separate requests, 5 separate threads. I believe it is because he wants a kit basically, complete with PCB. None forthcoming, he starts another thread.
    Which leads to a third point, a Google translator is probably being used. The OP may not understand a word of English. When the translation is too garbled to understand up pops another post.
    I think Soren may have something in that realm, it's been a while since he visited the site.
    To me this is a gray area, since this is for law enforcement. Small towns (wanna bet the OP is really remote?) cars and mods are paid for by the local police officers. The town I grew up in was something like that. They are typically speed traps, because it is one way taking care of their cars doesn't come out of their personal budget.
    So we'll have to defer to the moderators judgment, but we need to know one way or another. If I'm right about the English issue expect another thread.
    To the OP: Not speaking English, or English as a second language, is not a problem. We get that all the time here.
  17. marshallf3
    Jul 26, 2010
    2,358
    201
    Ever notice how a lot of these type posts are usually from brand new members and they need the answer right then - as if the homework project is due the next morning?
    Probably a good thing they didn't have the internet the two times I went to college, we actually had to study. If I recall we did have the basic 4-banger calculators the first time but slide rules still dominated. I've still got a couple of Pickets and K&Es sitting around somewhere, nowadays I've got two of the trusty old HP-48SX handheld programmables, they're actually small computers that will even solve for variables inside complex calculus equations if you can program well enough in RPN.
    When you learn how to use one of the older HPs you can do about anything. The newer ones just aren't the same by any means.
  18. Wendy
    Mar 24, 2008
    20,772
    2,540
    What!?! You don't like reverse polish! Who knew.
  19. marshallf3
    Jul 26, 2010
    2,358
    201
    What I love best about it is if I leave my calc on the desk at work (have one there and one at home) and someone picks it up to try and do a quick calculation. :)
  20. ke5nnt
    Mar 1, 2009
    384
    15
    I posted a thread similar to this one quite a while back, but like most of my threads, I post what I've already done and learned myself (as I have no actual electronics education from any institution). I find it quite enjoyable to learn and figure crap out myself, not to mention rewarding!
    Thanks to AAC members and books, yes, actual paper and ink books! I have been able to learn how to read/draw schematics, design a PCB, put components together to make things work, write Assembly code, program that code into Microcontrollers, and much much more. If I remember right, my very first project was 2 flashing LEDs with a 555 timer. Looking back on it now, it's the simplest thing ever.
    I did notice actually, quite annoying. Learning takes time... time takes patience... both of which are pretty much required for the AAC program to work for you. If you have no desire to learn, and no patience for learning, you should probably not be messing with things that require electricity, which can kill you. Is this the same person that wants a rice dispenser?
