Happy New Year!
Searching on the forum, there are very few threads about polarized vs non-polarized caps,
and none that talks about their cost (that I could find)...so here we go...
Recently I was building a little board to play with a generalized 555 timer.
Two pots - 100K and 1meg - and a row of capacitors from .0001 uF to 220 uF -
all connected to dip switches so I can easily change the capacitance.
It allows me to put the 555 in an infinite number of "states" and watch LEDs blink off and on.
While I was soldering the caps, I noted on a 1 uF that there was now "white line" that I had to line up with the negative side of the circuit.
I also noticed an "NP", and decided to do some research.
(I'm sure I just hit the Jameco "buy" button based on the value I needed)
Now I know that there are "polarized" and "non-polalrized" (NP) electrolytic capacitors - duh.
I searched a bit more and read things about using the NPs in AC circuits, and that the NPs cost more.
More research.
Here are some data from Jameco:
Capacitance___________Cost NP____________Cost Polarized
1 uF___________________.12__________________.08
3.3 uF_________________.10__________________.15
4.7 uF_________________.06__________________.09
So I wonder about the following:
a. There seem to be fewer values of non-polarized caps.
b. For a hobbiest, there is no great difference in price between polarized and non-polarized electrolytics
c. For "high" value capacitance in an AC circuit, you have to use an NP cap.
d. If you can find an NP cap in the value you need, and it's not too expensive, use it over a polarized cap.
Are these correct?
Do you have any other thoughts on the difference between NP and P caps?
How do you use them?
More research.
Are these correct?
