Polarized Capacitor in reverse direction??
rrrchandu
Joined Aug 9, 2010
28
I am very much confused with the polarized capacitor's response when it is charged with reverse polarities, i.e. its negative terminal connected to positive terminal of battery and its positive is to negative of battery without any resistor in between.
:confused:
ErnieM
Joined Apr 24, 2011
8,377
Back at my first job we used to do just that for fun, take an electrolytic cap, put it on some stiff leads, slide it along the floor under someone else's bench, and turn it on with reverse voltage from a lab power supply.
They rather quickly exploded. Loud bang. White smoke. Confetti too.
Pretty cool. Kids, don't try this at home.
JDT
Joined Feb 12, 2009
657
This will normally cause very high leakage current. The capacitor will be damaged. Sealed tantalum capacitors will quite possibly explode!
ramancini8
Joined Jul 18, 2012
473
Reverse polarity reverses the chemical process in the capacitor (depending on type) causing a gas buildup that sometimes explodes. Other types have a reverse reaction with less gas buildup, but the quality of the capacitor (leakage current) is degraded. A parallel diode is required if voltage is reversed momentarily, but using a nonpolarized capacitor is better practice.
rrrchandu
Joined Aug 9, 2010
28
thank you all.
usually a polarized cap is used with bjt amplifier as input cap, but in reverse direction.
what's the reason there? i am not understanding
Wendy
Joined Mar 24, 2008
23,429
Tantalum tend to simply catch fire like a match head in my experience.
You can not attach a electrolytic backwards without damaging it. There is, however, one exception to this rule. You can make a non polarized cap with two electrolytic caps, it is an old trick. The forward biased cap takes the strain.
If you don't know how to upload a attachment this is how...
How to upload an attachment.
To attach a document or picture to a post
Click "Go Advanced" at the bottom of your post,
One of several options will pop up,
Click "Manage Attachments" much further at the bottom of your post,
To upload a file from your computer click "Browse", then select the file.
Schematics should be .gif or .png format, pictures should be .jpg. .jpg formats will fuzz out schematics, and should not be used for that purpose.
If you want to display this file there is an old thread I made,
How to Display Attachments Full Size
30,823
A BJT amplifier uses a capacitor to pass the AC signal while it blocks the DC voltage. If you allowed the DC to get to the input of the BJT it would mess up the critical base bias of the amplifier.
Ideally, you would use a non-polarized capacitor but any cap over 1μF is expensive, hard to find and physically large. A capacitance less than 1μF is too low in value and the amplifier would have poor response at low frequencies.
Hence an electrolytic capacitor greater than 1μF is substituted, usually 10μF-47μF for the input side depending on impedances and the frequency response desired.
The output capacitor to an 8Ω speaker would have to be 2200μF-4700μF if you want to achieve decent performance below 100Hz.
Which way should the electrolytic capacitor be connected?
"Reverse direction" is a misunderstanding.
Simply, the capacitor should be connected with the +ve lead towards the more positive node of the circuit. That is, you want to maintain the correct voltage bias on the electrolytic. It should never be reversed biased.
Hence one has to examine and analyze the two nodes of the circuit where the capacitor is to be installed. Determine which node is the more positive and install the capacitor accordingly.
