Polarize Vs. Non-Polarize Caps.
Discussion in 'General Electronics Chat' started by Lotus, Oct 11, 2007.
  1. Lotus
    Oct 11, 2007
    I'm a newbie both in here and in electronics, but i must say that you have a great forum. :)
    I have some questions concerning capacitors:
    Can i replace a polarized electrolytic cap with another one non-polarized polypropylen or film in a hi-fi speaker crossover?
    What you guys think are best, polypropylen or film caps ?
    Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Poly would probably be a bit better, as to performance. But look at the price per microfarad compared with electrolytics and you will probably want to stay with the polarized caps.
  3. carcia
    May 12, 2006
    polarized caps I think is the best, the price make difference
  4. nanovate
    Distinguished Member
    May 7, 2007
    665
    @OP
    it depends on which caps you are replacing. If they are in the signal path then you should use the high quality film caps. If they are for bulk capacitance or decoupling then the price (and size) calls for Al electrolytic
  5. Lotus
    Oct 11, 2007
    Thanks for the input guys.
    Maybe i stick to electrolytics.
  6. cumesoftware
    Apr 27, 2007
    1,330
    11
    A polarized electrolytic cap in a crossover seems strange, to say the least. I think you may have a non-polarized aluminum electrolytic cap (yes, those exist too). If you have to replace, you can use a mylar cap, which is better for sound than a polipropylene one. Of course, the better, the more expensive will be.
  7. Lotus
    Oct 11, 2007
    What you guys think of these caps ?
    [​IMG][/IMG]
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Nice color. Lots of capacitance there. Is that a Phillips logo?
  9. Lotus
    Oct 11, 2007
    Yes, polyester film from Philips. Are they any good?
  10. mozikluv
    Jan 22, 2004
    1,437
    having caps in an audio signal path is either, it has to be there or avoid using it.
    about the phillips polyester cap, in general its okay but a metallized poly is better. however between polyester and tantalum, tantalum would be the better choice.
    a polypropylene would be a good choice since it has nearly the same relative qualities of DF and DA as polystyrene. these 2 however has a considerable cost factor.
    for an open pocket a teflon cap will nicely do:)
    moz
  11. nanovate
    May 7, 2007
    665
    polycarbonate is another option.
    I'd be careful with tantalum though.
  12. cumesoftware
    Apr 27, 2007
    1,330
    11
    We are talking about crossover networks, therefore, AC circuits. No polarized caps there.
