Polarity of the capacitor.
Discussion in 'General Electronics Chat' started by Lightfire, May 23, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    One of the capacitors in my schematic has a polarity (I guess).
    Please take a look at my schematic, please.:DPlease look at the capacitor which is circled by a black circle.:D
    Okay, as you may see on the top, there's a "+" there.
    Thanks. please.
  2. debjit625
    Apr 17, 2010
    790
    186
    Yes,so what?
  3. Lightfire
    Oct 5, 2010
    690
    21
    Ooops, I forgot my question. :D But there is no indication of the polarity in my actual capacitor. :( :(
    pls~
  4. ke5nnt
    Mar 1, 2009
    384
    15
    A black stripe on an electrolytic capacitor indicates the negative side. If that doesn't solve your mystery, perhaps a photo of your particular capacitor would help us better guide you.
    Lightfire likes this.
  5. Lightfire
    Oct 5, 2010
    690
    21
  6. ErnieM
    Apr 24, 2011
    7,436
    1,625
    A part number would help us find it for you, it would also help you find it too.
  7. Lightfire
    Oct 5, 2010
    690
    21
    Number? The number I guess was "1nK63". :)
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    About 40 years ago, polarized electrolytic capacitors had a "+" marked beside their + wire but now an arrow marked with a "-" points to the - wire.
    EDIT: 1nK63 is a non-polarized metalized plastic film capacitor that is 1nF (0.001uF), 10%, 63V.
  9. Lightfire
    Oct 5, 2010
    690
    21
    But the capacitors I have purchased is not an electrolytic, I guess. Based on the receipt, it was ceramic. :D
    help please
  10. debjit625
    Apr 17, 2010
    790
    186
    By the picture of "1nk63" around 0.001uF ,it looks like metalized polyester film type ,it is non-polarized i.e.. it have no polarity.As per your 555 circuit you should use a one micro-farad (1uF) electrolytic capacitor which are polarized.
    Good Luck
  11. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    It would help if you could tell us what your circuit is supposed to do.
    Also, as AG and debjit625 mentioned, the blue capacitor has a capacitance of 1nF, not 1uF (as needed for your circuit). You will need to find a 1uF capacitor, which is most commonly electrolytic (in my experience). It should be very easy to find.
    Good luck!
    Der Strom
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    I have some 1uf metalized plastic film capacitors that are very small (6mm wide x 8mm tall x 2mm thick) and have a 0.2" leads spacing. I also have some small 1uf monolithic ceramic capacitors marked "105".
    Both are not polarized.
  13. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Okay, I just have seen a lot of 1uF electrolytic caps (polarized). If that is what his circuit requires, it shouldn't be hard to find some.
    Der Strom
  14. Audioguru
    Dec 20, 2007
    9,411
    896
    1uF capacitors are available everywhere but maybe not at the "market" where he shops for electronic parts.
    I shop for food at a nearby market and buy electronic parts at online electronic parts distibutors and at some nearby electronic parts stores. One store has "surplus" new unused parts and products. I bought some Name-brand tiny switching power supplies (made for modems) (5V at 2A and on the case it says they have a trimpot inside for an adjustable voltage) at a very low price.
  15. Lightfire
    Oct 5, 2010
    690
    21
    I want to buy online (if I can only) but there are some reasons;
    I am scared to be scammed.:eek:
    I don't have any credit card.:eek:
    The shifting.:eek:
    The only thing I am thinking why I am receiving wrong electronic parts is because I am not the one who's buying it.:)
  16. Wendy
    Mar 24, 2008
    20,772
    2,540
    The person who sold you the parts probably didn't know the difference himself. This problem is world wide, but most small stores have folks who know.
    You can use a nonpolarized capacitor to replace a polarized capacitor, always. The reverse is not true.
    This is why you need to learn how to read the markings off the part, I discussed this in your other thread.
    Many DVM meters have a build in capacitance meter. It isn't quite a standard feature, but it is getting there. I don't remember if the meter I sent you has one or not.
  17. Lightfire
    Oct 5, 2010
    690
    21
    But as you stated, an 1nK63 is a 0.001μF capacitor. But my schematic required a 1μF. So maybe, I can try what did somebody say 1μF"microfarad" capacitor. is it Ok???
  18. debjit625
    Apr 17, 2010
    790
    186
    Catapult,you can post your parts list here so that we could guide you what you need.
    And here is pic of 1000 micro-farad 25V radial electrolytic polarized capacitor.
    The dash and arrow mark on the side of the capacitor specifies the negative terminal lead.
    Yes
    Good luck
  19. Wendy
    Mar 24, 2008
    20,772
    2,540
    Guys, IT DOES NOT MATTER WHAT THE PART LOOKS LIKE!!!
    The part identifier is what is important. PERIOD!!! If he gets an unpolarized 1µF capacitor (which are VERY common) then it will work.
    Lightfire,
    Your cap is a 0.001µF. I am sorry, but you have the wrong part. Look for one that is labeled 1µF or 105 on the package.
  20. Lightfire
    Oct 5, 2010
    690
    21
    But what kind of capacitor:confused:
